I did the HR 17mm hubs with 10mm offset and they work great! ??I was thinking about going to 17mm but I'm worried some wheel and tire combos will rub.
https://www.amazon.com/gp/product/B0015U3EM0/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1Are people changing the wheel hex hubs on the senton 4x4? If so what to? Or where can I get some tires? Lol blew one out and cant seem to easily find a set that fit the hex hubs.View attachment 39985
12mm hex has more options for 1/10 wheels than 17mm does but 17mm is a much better hex as far as durability goes. 12mm hexes are easier to strip the hex itself or the wheel.
As I mentioned in another thread I think the 12mm hex being easily stripped was part of the reason why Arrma went with the 14mm hex instead of 12mm.
That being said I think I would probably still go the 17mm route there are a few options that you can do, Hot Racing makes some 17mm hex adapters that work or you could use the Typhon 3s hexes.
No because the Typhon axles don’t use the same nut as the other 3S/4S line. You can use the Typhon hex’s if you also swap to the Typhon axles. But the stock Typhon hubs don’t extend your offset. The HR ones give you 10mm of offset and use the threaded axles.so if i buy the standard wheel hexes from a typhon 3s (ARA310904) it would fit a senton 3s blx?
thanks!, sorry my Englisch is not that good, but if im correct: when i buy the HR 17mm hex adapters i don't have to change anything else?No because the Typhon axles don’t use the same nut as the other 3S/4S line. You can use the Typhon hex’s if you also swap to the Typhon axles. But the stock Typhon hubs don’t extend your offset. The HR ones give you 10mm of offset and use the threaded axles.
Typhon Axle
Senton Axle
Correct. The HR hex’s come with everything you need to mount 17mm hex wheels on your Arrma 4x4.thanks!, sorry my Englisch is not that good, but if im correct: when i buy the HR 17mm hex adapters i don't have to change anything else?
Can you link the right ones pls?Correct. The HR hex’s come with everything you need to mount 17mm hex wheels on your Arrma 4x4.
Size wise yes. However keep in mind the power it takes to spin 3.8 based wheels. You will be popping driveshafts and overheating often if you run large tires on the stock 20T pinion. Drop to a 15T with big tires to avoid these issues. ??I finaly have them for my senton 3s. so can i now put on every tire that would fit a senton 6s?
Not if you are running ST sized tires. Only if you run MT sized tires, like a MX38 or similar.so if i want these tires that are usable on a senton 6s i need to change mij pinion to 15T?
https://www.toprc.nl/louise-sc-pioneer-shortcourse-banden-set-lr-t3148sbm.html
( i thought the senton 3s and 6s tires were almost the same size, not much bigger?)
