DoNoHarm
- Senton 6s
This car is running the stock blx 185 and stock 2050 motor and radared at 85mph. I’m not here to speed run, I just like that extra umph when I’m hitting a jump and nail it right at the base. So the truck overheats sometimes, not a surprise. Normally the truck cuts power and the red LED starts flashing. Today I overheated (again) probably the 4th overheat this ESC has seen. It doesn’t have a fan on it but doesn’t seem to matter because the truck is so light. I temped the heat sink at 205 Fahrenheit but couldn’t repeat it for the photo, because the gun kept reading the temp of the plastic (a whopping 158 degrees, wow that’s hot for plastic, that metal was hot as hell.)
The truck is on and running in the photo taken. There was no red flashing LED at all. Batteries were at 11.4 volts each, which is long before LVC should kick in. Even then, if it was low voltage cutoff, the light would still be flashing red. No lights! And a permanent brake. The esc had the brakes stuck on at the time of taking this picture and afterwards it cooled down, I tried unplugging it and plugging it back in with new batteries, but it still has the brakes on hard and flashes no green light upon startup. Thoughts? Mine are: don’t overheat your escs.
Edit: that red in the background is my temp gun laser. Sorry for the confusion:
Sweet update! Recalibrated her and it’s ripping once again. Let me make a mental note to get a fan. Man this just goes to show there’s always a way out of tragedy. I was getting ready to bury my venerable blx 185, that would’ve been so sad.
