Velodromed
Snatching defeat from the jaws of victory!
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
That is very good that you have it running. At some point you really need to move gearing to .08 mod (metric version of 32dp). It’ll hold up much better and that’s how they come stock, so the parts are easy to get. I like jennysrc.com for stock parts at a good price. I like to use the soft side of Velcro to seal off the spur case. It doesn’t interfere so much with clipping in the motor module and keeps a lot of the crud out.It seems my pinion with sleeve slipped down, luckily not off and just barley nicked the spur gear.
The 5mm I also got I missed it was a 32 pitch -_- but I have an extra 91T as well in case this didn't work. But it drove amazing alot more torque can't even do donuts on loose dirt without flipping now. The 48pitch 15T pinion gear holds now. Put thread locker on it just the tiniest possible amount so it held and I could still break it off. Just hit the two jumps a few times at home and it's running good. Will probably get new tape for sealing the spur because the 3m is a little tough to get the motor mount case back in and off but not to bad. Was very clean inside compared to last time with dirt in it from one run.
I'm just going to set it aside for now and probably go to the local rc store and get a new pinion maybe not a 15T so I can actually turn and not flip on stock wheels.
Very fun though, it is never really hot on the motor. I can. Touch it and it feels like warm 30&45 mins on 2s, doubt I'll go 3s unless I have a motor fan installed first.
Appreciate everyone's tips, I do try to clean it more now than when I first got it. Have new front suspension ordered and screws just because most are rusted and stripped from last owners sadly.
But will continue to look for a better pinion setup. Have new 14mm to 12mm wheel adapter as well to try and find more wheel setups just from the local shop. Will have to order some MTs
