Senton Arrma senton help please
coopermc
New Member
Hey my arrma senton is making a horrible grinding noise when I try and give it throttle and it wont move only make noises
Please help
Thanks
Smilinbri
RC is a hobby. Arrma is a lifestyle.
MD
  1. Felony
  2. Notorious
  3. Senton 6s
  4. Senton 3s
  5. Typhon 6s
  6. Vorteks
  7. Infraction 4x4
Just from that explanation and no vid it sounds like your gear mesh is off. Did you check the pinion gear and are the diffs filled with oil?
Johnny b
Florida
  1. Senton 3s
  2. Typhon 3s
Like Smili says. First slide out and remove motor module. Check pinion to spur mesh. If all fine, roll tires. With the drive shaft out, there should be no resistance and diffs should turn freely. Has to be one or another. Check Bearings on spur and ensure slipper is functioning and adjusted properly while you have it apart.Easy to pin down problem.
