Arrma senton mega blx 3s upgrades
hops08
Senton
I've upgraded to the blx 3s diff and spur gear with adjustable motor mount. I cant seem to get the slipper to seat properly on the input gear. It seems like it's a fraction to long. Am I missing something?
Any 41219help would be greatly appreciated
jondilly1974
ArrmaForum Fan
Toledo, OH
Kraton 4s, Typhon 6s, Typhon 3s
You got to lick it, before you stick it!!!
Sorry, I’ve had a few drinks tonight and my 8yr old inner self is surfacing.
I like to grease the skids on the motor mount before trying to push it back into the chassis. Also, tilt the top in first and mesh the input with the slipper rear. Then once that is meshed, slide the bottom of the mount block into the chassis slots. The grease will help that too.
hops08
Senton
That's not the issue. It seems like the input gear shaft is a bit to long. The slipper wont slide all the way in. The old set up slides in fine
bicketybam
BickeringBam - YouTube Mega Star!
ArrmaForum Fan
New Milford, CT
BigRock 4x4, Granite, Infraction, Kraton 6s, Kraton 4s, Notorious, Talion, Typhon 6s
I think I saw a post about someone else having this issue but I can't remember what the problem was. I think there was something else that needed to be changed. Maybe @Megasty knows.
Megasty
BigRock, Fazon, Granite, Infraction, Kraton 6s, Nero, Notorious, Outcast 6s, Raider, Senton, Talion, Typhon 6s, Typhon 3s
When you tighten the slipper completely, the end of the screw that holds the thing together will start to poke out the end where the input slides into. You can unbolt it & add a few m3 washers to the bolt head b4 the spring. You just need to add them, reassemble the slipper, fully tighten it, & look inside the rear female splined part of the rear plate to see if the screw is flush with it. It's kinda hard to see with or w/o a flashlight. I had to add 4 m3 washers but you might have to add more or less.
Dansb
Senton
I had the same issue when upgraded my mega with the 3s slipper clutch spur and motor mount. With the stock mega rear diff and input gear I took a hacksaw and shaved about an eighth inch off the input gear post and it fit fine. When I upgraded to the 3s rear diff and input it fit with no modifications.
