I just bought an Arrma Senton Mega the other day, charged the battery, adjusted the trim pots, and drove it around my house for a little while and its great, but now I want to upgrade it. The reason for the immediate upgrade is I want longevity and reliability out of this unit, because its going to carrying a LiDAR unit around and additional processing, and its going to do lots of driving. I have had a few RC cars before, quite a while ago now, and smaller units then this so I don't have a ton of experience with these. I have been building and flying drones for fun and industrial use for awhile now so I do have some understanding of what I am trying to do, but how much carries over to this I am not sure.
My goals are for this are;
- Convert to 4S (some of the payload has a 4S requirement)
- Convert to brushless motor and ESC (brushes in brushed motors wear out too quickly)
- Upgrade drivetrain accordingly as well
I think I probably want a motor around 2000kv, something like this;
https://hobbyking.com/en_us/turnigy-xk3674-1900kv-brushless-inrunner.html?wrh_pdp=2
But I am not sure if this will fit (diameter, length, shaft size). Inrunner motor sizing seems less consistent then Outrunners, I am used to the four digit number being the stator size in mm for outrunners (ex/ 4213 - 42mm diameter by 13mm long) but this doesn't always seem to hold true with inrunners, for the rotor or the can. If it does fit though it comes in a variety of KVs, as low as 1400 and as high as 2600 I think, roughly. If you have a recommendation for KV to keep the speed similar to stock at 4S that is appreciated (faster is fine, I can limit speed in software, but I don't need it winning any races). I can pick an appropriate ESC. What other parts of the drivetrain would be recommended to be upgraded in these when going brushless? I assume pinion and spur gears? Driveshaft? I bought this because is said the diffs were brushless ready so I assume they good?
As a side note, since I plan to upgrade a bunch of stuff, I will have stock parts I don't need that are brand new I can sell if anyone needs them, including motor, ESC, receiver and radio, battery and charger.
