Peeeenuuutt
- Senton
- Thread starter
- #1
Everything on my Outcast was caked in red loctite even the shocks.View attachment 27984View attachment 27985
Yup that’s exactly how it looks.. LOL
No, not stripped. Just completely torqued clockwise... that 17mm adapter screw really twisted my bit... wowzer. Still came out though.
This is the trick. I use a cheap ass torch from Harbor Freight and good to go. It's concerning at first but once you see it work, they come right on out with the pinpoint flame for just a few seconds.I was relieved when i got out every locktited screw out of my rig without stripping anything those little torch lighters are your friend
Only screw I striped was the pinion grub screw, as it was the first one I tried to remove. I had no idea everything had red loctite on it.I was relieved when i got out every locktited screw out of my rig without stripping anything those little torch lighters are your friend
That one gave me a scare i didn't strip it the head of the screw actually cracked in half luckily a little more heat it came right outOnly screw I striped was the pinion grub screw, as it was the first one I tried to remove. I had no idea everything had red loctite on it.
Thread starter | Similar threads | Forum | Replies | Date |
D | Looking to purchase an Arrma tomorrow. Need advice | Arrma 4x4 Mega & BLX | 26 | |
ARRMA Big Rock Crew Cab 3s BLX- HR Metal Drive Shaft install | Arrma 4x4 Mega & BLX | 0 | |
Max speed (All Arrmas) on stock electronics? | Electronics | 5 | |
P | Blown up center diff in arrma kraton, HELP!! | Chassis & Drivetrain | 3 |
