Arrma spring list / chart for 4s and most 6s vehicles
So for the Mojave EXB, are the fronts 70mm or 110mm and what are the rears?
I understand 70 front and 110 in the back. I´ll check it soon and try some springs from Ali. They are quite good but stiffness (k-factor) isn´t listened, only wire thickness...
More spring options for 16mm diameter, from Associated RC8
Fronts are 70mm length, Rears are 86mm length.
Just a note. These do fit over the Arrma 6s shocks, but they do not fit over the bottom of the shock collar. While technically these springs "work" for the 6s, line, the inner diameter of the spring is just 1mm less than the inner diameter of the Arrma line of shock springs.
I have compiled a list of Arrma spring part numbers with length and standardized rate info since I couldn't find an easy source anywhere else. These are all the diameter that will fit 4s stock shocks and most 6s models. I excluded Infraction / Limitless since they are not really relevant to the sizes listed here. 8s options are easy to find, and sorry 3s guys, you can just upgrade to 4s larger diameter shocks.
Of course Tekno 1/8 scale springs for Truggy, Buggy, MT, etc. will work with many similar options, but generally a lot more expensive per pair. Those charts are readily available. Team Durango 1/8 springs are still out there and will work also.
I found this info from digging through many kit/version standard parts lists on the website. I also found most of it straight off this cross-reference sheet that's available for current kits on the website, very useful!
http://www.arrma-rc.com/pdf/xref/arrma-parts-xref-A.pdf
Sorted by Size then Rate:
Length (mm)Rate (lb/in)PartpositionKits that included part:
609.70AR330500frontTalion 6s V3-4
703.80AR330233optionTyphon 6s
704.23AR330235frontTyphon 3s, Typhon 6s
704.57AR330532front4s Outcast and Kraton
704.75*AR330237frontTyphon 6s
704.76TD330781frontSenton 6s
706.50ARA330637optionMojave
707.00ARA330638optionMojave
707.70ARA330644stockMojave
708.10ARA330639optionMojave
708.60ARA330640optionMojave
764.12*AR330383optionTyphon 6s
764.50AR330384optionTyphon 6s
764.94*AR330385optionTyphon 6s
842.93AR330238optionTyphon 6s
843.17AR330239rearTyphon 3s, Typhon 6s, Senton 6s, Talion 6s V1
843.46AR330240optionTyphon 6s
844.00AR330533rear4s Outcast and Kraton
845.40AR330501rearTalion 6s V3-4
856.20AR330507frontKraton 6s V2-4, Outcast 6s V1-4, Notorious 6s
955.00AR330508rearKraton 6s V2-4, Outcast 6s V1-4, Notorious 6s
1103.20ARA330643stockMojave
1103.40ARA330641optionMojave
1103.60ARA330642optionMojave
Where is the fireteam
@Anthony jaques feel free to add and contribute. Doesn't hurt and makes you feel good ;)
So far I've found that the ara330782 is 72mm 5.54 lb in but I measured by hand and it is 95mm any idea why this would be so off
That would be the rear of fireteam
The ara330780 or front is 85mm with 6.91 lbs in
This overview was very helpful to pick springs for my Typhon 3s that is getting 6s shocks installed.
Stock springs of the Typhon 3s are:
Front: 70mm, 1.00n/mm
Rear: 85mm, 0.84n/mm
And I picked these springs for the 6s shocks:
Front: 70mm - ARA330637 - 1.14 n/mm (Mojave)
Rear: 84mm - AR330501 - 0.95 n/mm (Talion)
If this is irrelevant or repeated I apologize ahead but on a side not for yall with heavy rigs or need for larger spring rate check out east tactics video on century springs I got a set for my fireteam I was impressed
