Talion Arrma Talion 6S V4 2019 ? At Home ?
Arrma BackFlip LP
Arrma KATAR
Today I tried both tires on the water. (y)
The Backflip tires worked really well on the water.
Excellent control and good drift. :love:
The KATAR on the oval track the tires have a better handling, (y)
but the drift is more delicate.
I have a lot more fun with BackFlip than KATAR. :)
Yvan
The Kraton Body. :cool:
For those who do not like the body of Talion! :(
It easy to put other body. (y)
Only put body mount longer for the front.
he places himself directly.
Kraton 6S low profile. It's cool. (y):cool:
Yvan
A Kration! You may have just found my solution to wanting a truck style Talion. The road to bye bye Noto gets closer.
Nice Talion!
But I think the Kraton body is too big for the stock Talion wheels :unsure:
Whatever... Nice build!
Wow those lights look sick im so poor that i made my own tail lights powered byt the receiver i try to avoid to make holes on the body becsuse when it comes to remplace it it becomes a pain ect
Look at my friend. (y)
You need to change the front body mount. :cool:
You have to lift the wing of a hole higher. (y)
You have two trucks in the same setup. (y):love:(y)
The Talion is more fun to drive in the street and the big field and it is really stable. :)
Yvan
Just to need the replaced the decals Kraton for those of the Talion. :cool:
Nice Talion!
Absolutely not. The wheels are of good size.
You replace them with Arrma DBOOTS BackFlip (LP) and you have the perfect truck for a good mix of Kraton and Talion.
These are only choices that are offered to us.
It's up to you to choose your option.
Yvan
Thank you my friend. (y)
The lights are very easy to change. :)
But, I'm never replaced any lights until now.
I put lights on all my Arrma trucks. (y)
Yvan
Tested on the water! ?
Here you have the first pictures with the KATAR tires and the last pictures you have the BackFlip LP.
With the tires BackFlip LP, I'm never knocked down the truck, but the KATAR, it's reversed several times.
Yvan
I installed two more white lights for the front of the truck. (y)?
The Talion is really special. It is really cool this truck. :love:
I am going to school to try the lights and drive him into the children's games. With caution, drive slowly. ??
For the tunnel, all the children were with me.
Because the Talion is so fast out of the tunnel. :eek:??
He stayed on the field and ready to roll again. ?
Yvan
I received the Terrain Crusher SRC tires. (y)
The tire has good grip on wet asphalt. :cool:
The price is high but it will last a long time. :ROFLMAO:(y)
Yvan
:)Talion looks good with that wheel and tire combination.
I think PowerHobby sells these as Raptors on eBay for $120 a set. They look very similar.
Arrma Talion 6S V4 BLX SRC Crusher Belted Tires
I really like tires for turf. (y)
Yvan
Tested Backflip LP on the Talion today and am very impressed! I'm glad I bought them and for $60 shipped a good deal. I felt more comfortable landing big jumps because I've cracked Katar wheels twice. I do still like the Katars a lot and now have a good mix for any terrain I normally run.
Hey,
I have the same model 2019.
I quickly noticed that the rear dampers are much smoother than the front ones.
As I can read on the manual, it contains 2000cst of oil.
At the front I can believe that, but at the back it is much too soft to get close to 2000cst.
Someone who can state with certainty what thickness these are in front / back
I want to adjust this because it bounces too much in the front and is too soft in the back.
Hey,
That is what the fluids are but the reason it's softer in the back isn't so much the fluid it's because the rear springs are 5.4lb/in vs 9.7ln/in in the front. I tried like 7 different setups until I settled on stock in front, the v4 Kraton 6.2lb/in springs in the back with a mix of oil resulting in ~2300cst.
Thanks for you answer!!
I looked at my store, but the problem is that we do not work in lb / in, but in gf / mm
However, I would also like to try this combo. (just the oil not that thick. I don't do jumps and The problem with the high cst value is that it no longer filters the small irregularities.)
Do you jump a lot with the Talion?
Do you have some part number of the springs?
These are in the list for Kraton at my shop;
- 8941
-8948
-8944
-8929
-9095
-9096
- 8941
-8948
-8944
-8929
-9095
-9096
Yeah arrmas been shizo about some being published in lbs, some Nm, some gf. The Kraton rear springs I used are ar330507.
I do jump with the Talion at the outdoor track and also at the mtb pump track, usually long fast jumps that are like maybe 8ft high but like 20-30 feet long. If you're more inclined to do higher shorter length jumps like at a skate park the shock oil would probably need to be suited to taste. I find this spring setup to be pretty universal for whatever application I'm doing but shock oil is a lot more personal.
