Your question isn’t really clear. Are you saying when driving forward and applying the brakes, it instead goes into reverse instantly unless you double tap the brakes, then it will brake instead of reverse? That’s the opposite of what it should do. It should brake until stopped. Then you should be able to hit reverse again to back up.Hello, im having trouble with my Arrma Talion 6s EXB
Whenever im about to do a fully break while im driving it seem too reverse for a few seconds until i hit the throttle again.
Does anyone know how to fix this please?
If you are braking, that is using the throttleits confusing, if i break too long it will go in reverse for a couple of seconds without me thouching the throttle
Then what was said above, check your throttle trim. Recalibrate the ESC after making the adjustment to center if needed.true, but i still don't understand why it still go in reverse mode without braking, it does that for like 5sec after letting go off the throttle
