The C rating of the batteries will determine how much power you have. If you want lots of grunt, 50 or 60 C is where you want to be. As far as what is better, two 3s or one 6s, everyone has there own preference. Two 3s means you can keep going if one cell goes bad. Cell dies in a 6s, you're out of luck and the battery is garbage unless you know how to open and repair lipos. MaH will determine your run time.Hello guys, I just bought a talion and I'm hesitant in which batteries to put in the two 3s or a 6s with which of the two will perform better? I want more than everything a lot of speed and power
