Typhon ARRMA Typhon 3s BLX 13,6 inch width
What shocks are you running? Your car looks sick ????
Hello mOnk, thank you my friend, I use the typhon 6s shock with same spring and 40w front and 35w rear. I use a plastic cover any, use slice for make a sleeve inside the hollow ball cap shock because it 4mm and typhhon 3s use 3mm bolt :)
Samintrepid do you have any wobble problem with those hot racing adapters?
No Augustin805, no wobble with HR adaptor run perfect. The problem are probaly your tire or foam.
Samintrepid do you use anything in the shock arms to stop the shocks from rubbing or are they OK bolted on like the stock shocks?
At first I use nothing Adam but after couple week I see the rub and install a plastic washer of 1/16" thick approximately and now no rub :)
