- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
Now that Arrma has released metal differential gears for these are you going to re-visit the 3s Typhon speed project?
I already have the HR metal diffs ?????Now that Arrma has released metal differential gears for these are you going to re-visit the 3s Typhon speed project?
Clearly I am not up to speed with this line of Arrma cars....I already have the HR metal diffs ?????
When I blew the plastic diffs in the 3S with 8S power, I ordered the Arrma cups and the HR gears. Issue was that took over a month to get from China. Then I was having issues getting it down the road straight. Blew a bunch of S7s in the process. Got mad and shelved it in favor of the 6S, which is now an Infraction V2 8S ?Clearly I am not up to speed with this line of Arrma cars....
Understandable, the longer wheelbase is much more stable and crashes suck...When I blew the plastic diffs in the 3S with 8S power, I ordered the Arrma cups and the HR gears. Issue was that took over a month to get from China. Then I was having issues getting it down the road straight. Blew a bunch of S7s in the process. Got mad and shelved it in favor of the 6S, which is now an Infraction V2 8S ?
You’re up to date now ????
Well I had time today watching football waiting for mud to dry and decided to work on the T3SGT. Got it all adjusted and straight again (hope?). Hoping to make some passes with both speed cars Wednesday morning. Wind forecast is 4mph for once.Understandable, the longer wheelbase is much more stable and crashes suck...
Useful find. I've done the rpm arms and blx120 along with the kraton t2t brace (although do need to chop the front body to fit on standard posts as want to keep it low). Still running the stock motor with fan added.Looking at the center cross on these u-joints, if they made them just a little longer you could get an E-ring on them to retain the plastic tabs better. It would be a tiny bit more material. Adding a snap ring to the outside of the tabs is hard because it will restrict the other side of the joint from articulating properly. You would need something the shape of the tabs to go directly over them.
Oh I am sure I have gone thru a few chassis. Lost count a long time ago. I still have quite a few on hand just in case though.Are you still useinf the 1st, original chassis.i now you've had some crashs,curious if same chassis has survived..I've been in the hobby less time than this thread started.technoloy, upgrades,an nowhere move very fast in this hobby..I've been reading this this build that started in oct 19..
YOU ARE TRULY A PIONEER TO ARRMA PERFORMANCE BROTHER!!!!!!
