helpmethanks
- Kraton 8S
can you help me look for a heat sink for my typhon 6s v5 link pls i need some help not sure which one will fit sorry im still new
The heat sink that comes with the Arrma felony would work. The power hobby ones work but you have to put something under the motor for it to fit.can you help me look for a heat sink for my typhon 6s v5 link pls i need some help not sure which one will fit sorry im still new
I buy those cheap ones off Amazon that only fit half way around the can. They use 30 x 30 fans which is perfect for me since I'm using high power aluminum bodied ones now. Just use zip ties to hold them on. Been working this way for almost two years now on six different 6s models.can you help me look for a heat sink for my typhon 6s v5 link pls i need some help not sure which one will fit sorry im still new
The heat sink is to big and slides around so you need to put something. I use tin foil.What do you mean by having to put something under the motor to fit?
The PH/YR are bit loose on the Firma motor. Metal shim is needed. Arrma HS fits fine.What do you mean by having to put something under the motor to fit?
