helpmethanks
- Kraton 8S
im still learning but today i saw my typhon have wear on pinion gear just wondering is that normal ? any good brand pinion gear i should buy ?
i follow this but it for my kraton 8sEither it was to tight or to loose. I'm sure someone with have the right answer . I'll be watching for the answer . These are the first cars I've had where you can adjust the mesh .
i say around 10 runs even had the punch setting level 9 had it for 2 daysHard to tell but your mesh might be a little loose. How much run time has that pinion had?
do you think i can save it by make it little bet tighter ?Looks like it was too loose as it's wearing away and deforming the edge of the teeth. Honestly I'd just buy some stock replacements from Jenny's for like $7 and make sure to set the mesh right next time. I've ran stock Pinions in my rigs for months and months with no issues at all.
If you want to have your spur gear chewed up from the misshapen teeth and have to replace it as well go for it but I personally wouldn't even attempt as it's just going to cost you more money in the long run. Like I said jenny's has Pinions for like 2-3$ plus $5 shipping is a whole like $8i say around 10 runs even had the punch setting level 9 had it for 2 days
one more question i have 20 t pinion gear brand new can i just use it on my typhon and change TH/LIM 50/75/100 TO (50) and not worried about the temperature ???If you want to have your spur gear chewed up from the misshapen teeth and have to replace it as well go for it but I personally wouldn't even attempt as it's just going to cost you more money in the long run. Like I said jenny's has Pinions for like 2-3$ plus $5 shipping is a whole like $8
https://jennysrc.com/products/arrma...ars-12t-16t-steel-mod-1-5mm-outcast-ara8611v5
Or this one's not even $2 but out of stock just check daily as they update parts availability almost daily on Jenny's
https://jennysrc.com/products/arrma-mojave-6s-exb-pinion-gear-16t-steel-mod-1-5mm-shaft-size-ara7204
It would work but still might have some heat issues as it's a lot larger pinion. It will at least allow you to drive the rig until you get a new pinionone more question i have 20 t pinion gear brand new can i just use it on my typhon and change TH/LIM 50/75/100 TO (50) and not worried about the temperature ???
