helpmethanks
- Kraton 8S
hi im having a problem with my rc everytime i try to turn left or right it misses with the fan speed and esc restart again. here a video i made today pls help
i just check the servo and it connected rip my lifedo you think that your typhon dual rate is all the way tight or the servo is disconnected those are my 2 cents worth
This a V5 model right? I believe many have been having issues with faulty servos. Unplug servo from receiver and try turning it on.hi im having a problem with my rc everytime i try to turn left or right it misses with the fan speed and esc restart again. here a video i made today pls help
yes v5 only had it for 2 month i only used it i say 3 or 4 time i already message HHThis a V5 model right? I believe many have been having issues with faulty servos. Unplug servo from receiver and try turning it on.
See if it works and moved forward and reverse. Should be able to get a new one from HH with warranty
can it be the receiver ? i swear when put it away it was fineThis a V5 model right? I believe many have been having issues with faulty servos. Unplug servo from receiver and try turning it on.
I've read a few threads with that same issue. Receiver would make all the electronics glitch. They disconnect the receiver or replace it and it solves the issue.can it be the receiver ? i swear when put it away it was fine
ok look like the servo is dead i try the spektrum xbc1000 servo tester and did the servo test and it don't even move left or rightcould you use another receiver to test if it is the receiver or the car
