70.8 MPH with 23T pinion.
My god Cooter! That thing was completely vertical when it went by you! I can't believe it went back down on all fours after getting that high, but glad that it did.Even the 3S with all the plastic's are capable of some speed!
I'm anxious to see your results with that combo. I understand you're still running stock electronics? Will you be running a cap pack?Crazy wheelie going on there @cootertwo .
What spur gear are you running with yours then?
I'm running a 34T pinion gear as well in my 6S with a 38T spur gear but haven't had a chance to really let it stretch out properly yet and see what it can do. Still repairing mine if you haven't checked my thread.
Thanks Dutch. You picked an appropriate name for this thread. The "Journey" is what keeps this hobby interesting.Nice vid man! Good font choice as well!
I would have thought a 23t pinion would have given higher speeds. Correct me if I'm wrong but isn't the stock high speed pinion a 16t that's suppose to get to 60+ mph? Didnt think you would lose that much speed with the smaller grp tires.70.8 MPH with 23T pinion.
Yes I'm still running all the stock electronics, ...so far so good with no heat issues or anything.I'm anxious to see your results with that combo. I understand you're still running stock electronics? Will you be running a cap pack?
The stock wheels are about 20% bigger in circumference compared to the GRPs. Assuming the same RPM, the stock wheels in theory would yield something closer to 85 MPH, perhaps more due to ballooning.I would have thought a 23t pinion would have given higher speeds. Correct me if I'm wrong but isn't the stock high speed pinion a 16t that's suppose to get to 60+ mph? Didnt think you would lose that much speed with the smaller grp tires.
I can imagine that is one of the tougher DIY projects. In addition to a high wattage iron, be sure to use a large chizel or blade style tip. The larger mass will allow more heat to be stored and delivered quickly (ironically, conceptually similar to larger capacitors). How are you planning to heat shrink the solder joint? I imagine you'd have to unsolder the wires at the ESC or at the XT90?Man, i tried soldering my cap pack to that big a$$ wire on esc and got totally denied... My soldering iron was not having it... Just had to buy a big dog to finish this project... sucks... If anyone plans on soldering 6.5 g wire make sure you have a hot iron....
So Dutch just wondered have you tried the Typhon bodyshell on it yet since you've done your mods?
I assume you're going to have to reposition the rear body post mounts then somehow are you?
Looking cool AF so far, can't wait for you to get your first runs done.
God your beautiful! and the dogs gorgeous too !
You look like joe Manganiello!!! I'm not gay but if I was... OMG
But theres a thread In the premium members section that has a show us your pets so if you donate to the forum you can totally check out my pets and other premium members pets too
I use a small butane torch to solder the larger 6.5mm bullet style motor connectors; it is much easier and faster than using a soldering gun for sure. $20 saves a lot of hassell and timeI have a mamba monster xlx... It comes with motor connectors but i had to solder male connectors on the TP motor which i did successfully but the weller iron didnt have enough heat to tie in the cap pack to the battery wires cause they are like a 1/4' thick each.... I use heat shrink for all the connectors and joints...
