Sounds good!
No sin with the BLX100 - the main issue is with LVC, but you will be shutting that down for Nimh, so you should be good there. If you want to run Lipo, just buy a cheap lipo alarm and leave the ESC in NiMh mode.
One thought - with the 3650 3100kv motor, be sure and use a small pinion. 13t is the smallest you can do with the pre-drilled holes, but if that is not small enough (heat issues) you could oval out the 13t holes and drop in a 11t. Pinions smaller than 11t are hard sometimes to find.
