Pretty common problem, if you can even call it a problem at all. Some heat and use a punch or awl to tap it out. Arrma using tons of Red TL on the hubs set screw may contribute to that.Okay I'll try that and see what happens . Thanks
Yes they will be tight also.... been there....Yeah I got the pin out now . Now the hubs are stuck
