Domapen79
We started the design process. It's hard to make him wait and do it slow. Just working on his primer.
I believe you got the body for the granite voltage. The bottom is thinner and won’t cover the chassis from wheel to wheel. I made the same mistake once but fortunately I also had a voltage so just did it for that car.Granite 4x4
You made me double check. They fit right on. It's for the granite.I believe you got the body for the granite voltage. The bottom is thinner and won’t cover the chassis from wheel to wheel. I made the same mistake once but fortunately I also had a voltage so just did it for that car.
Look at the side view and you will see what I mean. Compare the side bottom part to the stock granite bodyYou made me double check. They fit right on. It's for the granite.
I see what your saying. We haven't tried to drive them yet. You are 100 percent correct. Need to see how it drives. Apparently I'm painting them wrong so we are just going to drive them out.
It will drive fine. when I first got into this hobby I took one of my stock voltage bodies and painted on the outside. It was my first attempt to paint. It did chip but it also didn’t really matter, especially if you’re using them as bash bodies.I see what your saying. We haven't tried to drive them yet. You are 100 percent correct. Need to see how it drives. Apparently I'm painting them wrong so we are just going to drive them out.
