Kraton As anyone swapped the kraton 150esc motor combo
jtmillerboy1
As anyone swapped the kraton 150esc motor combo swapped onto any other buggy and will it, does it work w lil changes?
I had the stock Arrma power system in my Traxxas Summit, the esc is still in it. The motor is in my Hot Bodies D8T. The escs aren't vehicle specific my Rustler has the BLX100 in it.
Welcome to the AF! What rig do you want to swap it into?
Sure. The Typhon 6S comes with the same power system.
Rite. I got a kraton 6 used n got lucky for the truck, transmitter n receiver, one 6s pack under 100$ I have two other buggies but not Arrma. But one I just rigged w a cheapish 150 ESC n 2100kv I just read it says Trackstar. Point is I can't even get a total full speed run. It's blown several wheels last few days. And I've clocked at 63 mph best. And the spektrum deal, I know will shred the quick swap 6s, I slapped on a 4s buggy. Can you recommended any tires to hold 60mph n be all chill. A pair for road. All I have is a few buggy tires and they can't handle the road when I want to do speed grounds actually got a little addicted to the speed runs I want to smoke a Typhon 6S with a kyosho lol
DBoots Hoons will be go for at least 100mph, I can't remember off the top of my head what they are rated for.
That's way good. Thanks I didn't know they were rated that fast, I'm just now building one of my buggies to be a Titan on the road. And keep my other same one for us for the tracks and off-road s. Thank you very much for the info I'm going to definitely see if they'll work on a kyosho. Appreciate it
They should work on anything with a 17mm hex.
