Hi guys i need help...what kind of shims to use on granite wheel axle to tighten a little bit and reduce a wobble?
I used these from Amazon, but you can find them at a LHS too. 12mm ID x 18mm OD x 0.5mm thick. I put one between the large axle bearing and the steering block.Hi guys i need help...what kind of shims to use on granite wheel axle to tighten a little bit and reduce a wobble?
That’s why I shimmed between the inner hub and the bearing, not the outside bearing and the hex. I wanted to push more of the driveshaft together, not pull it out further.I don't recommend shims unless you're using a really slippery material like the Teflon washers Traxxas uses. Else they're going to rub against the bearings. If you notice the wheel hexes, they have a raised lip on the inside half to press against the inner race of the wheel bearing so that the rest of the bearing spins freely in the hub.
Unless your truck is wandering down the road, I wouldn't worry about the slop. If it is wandering down the road, then make a left turn and drive on some dirt. You won't notice it then.
I recall you shimming the diffs? No?I don't recommend shims unless you're using a really slippery material like the Teflon washers Traxxas uses. Else they're going to rub against the bearings. If you notice the wheel hexes, they have a raised lip on the inside half to press against the inner race of the wheel bearing so that the rest of the bearing spins freely in the hub.
Didn’t you buy/have a shim kit you purchased and stated in one of your vids for shimming the diffs? Or am I thinking of a different kit?? Sorry can’t remember which vid. I swore you had one with various sizes.I was talking about the wheel hexes. Diffs and other parts of the drivetrain, yes, definitely shim as needed.
