Granite Axle stub screw
Domapen79
Aumsville Oregon
My axle stub screw snapped off inside the axle stub. Is there a way to remove the old broken screw head from the axle and put a new one in? Or am I in need of a new axle? Thanks I advance!
I have not replaced or removed those arms in a long time since I have gone with CVD. You should be able to take a 2mm hex wrench and screw it out from the other in through the center of the driveshaft. I had to get longer wrenches for that...
Hope my memory is correct.
Welcome
Found this...
So I should have asked if you tried this will it not screw out can you get a wrench on it
I can take the stub off. The problem I have is I need a way to get the broken screw out of the axle to replace it.
Like Camaroboy said. Don't think the screw will come out without separating the universal joint and compromising the axle. Better off just replacing the axle.
Play it safe🤣 I can’t believe I just said that. Do you have any left hand twist drill bits? Sometimes that works for the end in the metal. If not replace both bits.
