Well guys I received my 12t brushed motor from Arrma Monday, I was running it around last night in my backyard and the thing started making a grinding noise so I took it apart and I thought maybe the pinion gear came loose. Got to checking and found the front bearing on the motor is egg shaped and the shaft has allot of play. Guess I will be calling them again Monday for another replacement. I'm going to order a Traxxas Titan motor and try that and try and get rid of this piece of junk. I hope the spur gear isn't damaged, it doesn't look like it is but it wasn't making contact with the pinion when I got the motor assy out.
