- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
After totaling out my $peedrun typhon yesterday I decide to convert my squrrialy swb notorious into a 4s park terrorizer..
I love running a light ride an ripping it up,dodging trees, etc.swb setup right can be as fast as stock 6s,the lighter weight,right suspension setup an handling becomes epic..I live right up against a big city park.cant believe they haven't banned me yet.lol anyway here's setup
Swb typhon arms kraton steering blocks&hubs.
3.3 diffs with 46t spur all 3 stuffed with 30million diff fluid
Mmx6s an I tryed 3 different tp motors ,same yowoo 6000mah 100c 4s,about same top speed gearing adjusted for kvs.first the tp4040-2100kv.7d 22/46..great pow an torque,had in huge mojave an it screamed with max8.stayed cool most all throu pack ,took it easy towards 120s..temp gun used alot throu testing these.
Next tp4050cm 2300kv 8d 19/46 had more torque, but not the pow pow I like.did not seam as responsive as the the other 2.ran cooler than other 2 thou.last I used the tp4030-2070kv 3y I think.23/46 an it had the pow pow ran okay
.but got hot fast.im running 4s 40mm on esc an 4s 50mm on all 3 motors.after pulling logs my predictions where right.2100kv was 1hp+ more than other 2 .just screams on 4s with this setup in swb typhon .power ,weight for me to just drive Dat biotch.ran 44mph across grass field.
So Mmx6s tp4040-2100kv 22/46/13/43 gearing running buggy tires ,blou up 3 tires today
