Balance cable splitters?
chilly81
  1. Fireteam
  2. Granite
  3. Typhon 3s
Has anyone run across any balance cable splitters/Y cables? Basically a balance board, but without the whole board - something to simply split the (6S) balance connector into just like a balance board would, but without a big ol' balance board.
If those simple 1S-2S-3S-4S-5S-6S single adapter boards had a daisy chaining 2nd extra 6S connector, it would be perfect, but alas, they do not.
polly
Netherlands
  1. Fireteam
  2. Kraton EXB
you mean like these:
https://www.banggood.com/nl/2-Set-J...p-1603783.html?rmmds=myorder&cur_warehouse=CN
chilly81
  1. Fireteam
  2. Granite
  3. Typhon 3s
Yes, I have a 6S balance parallel charging cable, before I got my parallel boards. One example, like mine, with 6 connectors:
https://rotorriot.com/products/parallel-balance-cable-6s
Or with just 2 connectors:
https://www.buddyrc.com/products/jst-xh-6s-parallel-balance-cable-x2?variant=30274513305686
Yes! Perfect, thanks... idk why I couldn't find them.
@Diem Turner that is a nice balance board to be sure, but I'm often just charging two big car batteries in a Bat Safe, and having simple Y adapters are just easier to handle trying to fit everything in the box. For quads and small batteries, I'd use a normal one like that.
@polly Those are just to go from 6S to some other count. There's no splitting. Well, I guess technically there is if you wanted parallel charge a 3S and 4S battery together :) (kidding - don't try that)
