I always balance charge, it’s safer, and better for the LiPo.Do you balance or charge , or go back and forth ?.
Just charge the lipo. It doesn't matter a lot. Once in a while I will just put it on balance mode and let it charge up and take its time.Do you balance or charge , or go back and forth ?.
Always balance charge and put into storage after use, even if just for a day.Do you balance or charge , or go back and forth ?.
I do the same. But occasionally, if I know I'm heading out to bash early the next morning, I'll charge packs the night before, which is usually only 6-7 hours before I pack up and leave.Always balance charge and put into storage after use, even if just for a day.
Same here. I don’t like fast charging So will slow charge the night before and then back to storage when done the next day. I alternate sets of batteries between days.I do the same. But occasionally, if I know I'm heading out to bash early the next morning, I'll charge packs the night before, which is usually only 6-7 hours before I pack up and leave.
