Kraton Ball lube
I use white lightning clean ride bicycle chain lube on all my external stuff. Hinge pins, ball ends, cvd joints, king pins, pivot balls, dog bone ends, spurs/pinions... I put it on after a bash session or after I fix a truck so it's fully dried the next time I run.
Nothing is truly needed but if you do use something that is dry and lubricates, else you attract dirt and makes it worse.
Graphite is my go to dry lube. This is under heavy mechanical stress. Wax, PFTE etc won't hold up.
