Jim Laffey
What camera did you use to film your video?
GoPro Hero 6 Black. Filmed at 1080p 240 fps. Edited with PowerDirector 17.What camera did you use to film your video?
I am not sure I understood the end of your video. What is this lvc you speak of?
And as far as the short-course debate, my favorite Short Course Truck currently has a bug body on it. LOL. Short course trucks are cool if you're running across flat ground. When you really want to start bashing though, that body just seems to get in the way more than anything. The size of the truck is nice for bashing, though.
I set them up as close as I can get to standing straight up. So out at the top and in on the bottom. I have v2 outcast and kraton so my shock rods are only 3.5mm. In my head I think it has less chances of bending if they are positioned closer to straight up.Got both Arrmas fixed. I left out the spacers on the Kraton. Not only did the CVD pull out, it bent.
If removing the spacers doesn't work, my other options are shaving down the RPM arm or going back to stock. The CVD is popping out upon full compression of the shock, so droop isn't the issue. Would adjusting the points where the shock attaches to the shock towers and A-arm help? Maybe move them out?
I didn’t run the stock tires for very long and I certainly wasn’t jumping it back then. You make a good point. There could be something to that.Do you think it’s the bigger tires? Was it happening before you put the Trenchers on? I have those same tires but have not run them yet. Notice that the chassis just barely bottoms out with them on.
