Was a long day, but minimal casualties. Left the house at 8:30am, got home at 3pm. Used up all 10 of my packs I took, did some damage to all 3 of the trucks, but all still drivable.
Outcast:
No big changes on the outcast. Just driving it and finally getting some enjoyment out of it again.
Stampede:
Had modified the worn out hot racing steering drag link by drilling it out and installing some 3x6x2.5mm boca bearings in it. Greatly reduced steering slop and hopefully removed a wear point that's annoying to fix.
ERBEv2:
Put a set of hot racing 1/2" (10mm) offset adapters on it and switched back to my trencher 3.8's. Also dropped the pinion down to 19T, but will probably change it to 20T since everything ran relatively cool. Didn't care for the stock talon ext tires. Too little grip and too little sidewall for my taste. Now that I have the adapters, I'm thinking of ordering a set of backflips for it. I really like those on the outcast. Will see how it does.
Damage:
Busted a rear tekno shock end on the outcast, had a few spares with me to fix it. Ordered some Nero HD ones to try. Also pretty sure I stripped the bolt hole threads in my hot racing sliding adjuster plate. @bicketybam is hooking me up with a replacement. (thanks again!) That happened near the end of the second set of packs when the motor moved on me. Which reminds me... the pinion may need replaced, forgot to check. Also busted the center body tower/cage thing pretty bad.
Broke a piston on one of the rear revo shocks, it still drove, was just bouncy and bottomed out harder than usual. Also broke a rear turnbuckle end, was able to fix that while there.
Pretty sure the stampede is still good... might need a few ball ends replaced due to them getting stretched a bit on the upper turbuckles.
Outcast:
Stampede:
ERBEv2:
Damage:
