- UK..
- Infraction
- Mojave EXB
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 6s
I'm still waiting.....
The wait is over...!!! It's finally here ?
First job, sort the diffs...!!
Second job, sort everything else ?
You can adjust the droop from below if you compress the shocks all the way. It gives you just enough clearance to get a driver in there.Guess what, the front diff was practically empty from the factory ? and the center was the same..
Bit disappointed as I got fake droop screws that you can't adjust unless you take the suspension off..
Look at the bolt below there is no hole in it for a hex driver, so you can't adjust it from above ? so I fitted some bolts from a packet of ARA480017 I had laying around, I know Arrma do these bolts on their own also..
Few spares and first upgrades M2C shock standoffs
Droop screws fitted so now all adjustable from above, along with rebuilt diff full of 60k, couldn't get any 50k..
Managed to get one 0.15mm shim on the crown side, diff feels nice and tight..???
Mobil XHP222 grease just in case you want to know, this stuff is sticky as... ?
Quick test fit of the servo ( in EXB colors ? ), can't wait to see how powerful this thing is on max voltage.
Haven't decided if I'm going to stick with the EXB mount or go with my original GKA one..?
Put a longer caphead bolt and flipped it the other way up, also added 2 washers on top of the servo saver just so I could get the whole thing level..
I like the look of the red of the EXB servo mount but the GKA one is much better I think..?
That's it for now.....
My way is much easier though..?You can adjust the droop from below if you compress the shocks all the way. It gives you just enough clearance to get a driver in there.
Awesome job ?? this is how they should have been shimmed by OEM - on the OD, not IDSo onto the rear diff...
There has been a lot of talk about the rear EXB diffs, I've read all the posts on here and I've heard more theory's.
As I'm in the UK I can't get any LSD star plates ( that's what I'm calling them ) so I decided to come up with my own recipe for the rear diff, I can get shims in so many sizes it's crazy so that's what I'm going to do..!!
Lets begin..
Plenty of grease on the outside, there was practically no oil on the inside though just like the front ?
QC on this car is really bad in my opinion..?
I had a shimtastic time doing this..?
Top row is the LSD replacement shims, ( next row is hub axle and camber spacer, they are for later ) all sizes are in MM
Next are the shims to replace the Arrma ones ( ARA709060, ARA709059 ) as they are also out of stock in the UK ?
So this is my recipe, the following will explain everything you need to know..?
Firstly I measured everything individually and noted the best combination of sizes, I had ordered a selection of 10 of each size as I was just planning on experimenting but in hindsight I should have bought 20 of each ?
You'll see that my measurements come up .2 short, but I'll explain that in a minute.
Next I noted the stated size and the actual measured size..!!
Everyone told me, including Arrma you can only use two shims under the pin if you run the 3x LSD plates, well balls to that ?
I tried lots of different combinations of shims above and below the pin, also different combinations of the bigs shims.
In the end, I used one of each of the Arrma shims plus that 0.1 shim, they all happily went under the pin and everything turned smoothly.
So my final setup is everything you see in the picture below EXCEPT the LSD plates..!! this is of course on both sides of the diff.
Sorry I forgot to take a pic of it all laid so you'll just have to believe me that it's all there..?
The big shims support the sun gear really well, once I'd put it all together it was buttery smooth with no play in the drive cups whatsoever.
Best of all it's a totally open diff..???
I chose 20K this time as my other Kraton runs 30K and it doesn't turn in very well, you can see the stack of shims under the sun gear if you look ?
When I re-fitted the diff I squeezed 0.2 on the crown side and the diff is nice and tight and spins freely..
You can see in this pic the double headed droop screws AR727410 that I used too..
Finally just to finish up the rear diff housing, I always put a longer bolt with a nut on the lower tower mounting position as it stops the bolt pulling through the housing ( after a conversation one day, top tip provided by Mitch aka M2C )
Hope that all makes sense, good luck and enjoy your diff building..??
So that's it for now....
great info thanks!!So onto the rear diff...
Lets begin..
