The beefy ness! Nice!It's arrived...
TpPower/Max5 combo worked out cheaper than the Castle xlx2/1100kv combo, hopefully it's just as good if not better..!!
Awesome brother! Love that body… might have to adjust some gearing on that one haha. Maybe slip the other spur in thereSo it's all in..!!
Starting with a 26T/47T combo and see how it goes, motor o-rings™ fitted as always
Changed the top motor mount bolts to 3mm capheads for a better bite and less stripped bolt heads, tried to do the lower one too but there isn't enough clearance between the chassis and the mount, so I've left the lower one stock...
All back together ready to go and give it a bashing.
I'm out and ready to go.!! ( note to self, put air in NSF car tyre..!! )
Top speed 44mph ( slower than stock )
And just for 's and giggles 0-40mph drag run..
It may be slow, but it's terrifying as it come hurtling towards you with its bum squatting and its nose in the air..!!
View attachment 164076View attachment 164077
On the 0-40 hit did you have to pedal it in the middle?So it's all in..!!
I've got one waiting in the wings just incase, but Arrma say you can fit a 31T with the 47T spur..!!Arrma has a 39t spur if you run out of room on the motor mount.
Yes it's a 5660 8D 1054KV, it's a complete beast and works really well with the Max5..Which TP motor is that? 5660? How have you found it with the Max5, happy with the pairing?
Can't believe it's been two years since my last post..!!!
With all the recent hype over the new 8s EXB RTR's, I thought I'd take out the O8s this weekend
It ran fine, but halfway through the run I noticed it was running excessive rear camber on the lefthand side.!!
Everything was working fine so I kept running it till the end of the batteries then went home..
Once I got home I decided to take a look at it and try to figure out what was causing the extra rear camber..
Well, at some point during todays run it must have taken a hard landing on the rear left, punching the camber link into the ball end, what's strange though is the ball end isn't broken nor is the thread damaged as I was able to just unscrew the ball end and re-assemble everything..
On closer inspection though it seems I also bent the left front driveshaft, this truck bends driveshafts practically everytime I take it out, so I have spares that I just swap out then fix later quite handy that it uses the same shafts front and rear..!!
Till next time......
