Yeah was my only option and worked out wellcouldnt fit 2 batts in the tray I presume? Good job though, it keeps the CG low
What's the specs on those two batteries? If you wanted to stack them, wasn't it possible by just removing the sliding hold down at the front of the tray?I was cutting away and ended up with this
Specs not sure it was the Height but when stacked that sliding tray sits up 3/4 and now the body doesn’t have bubble no more so I modified itWhat's the specs on those two batteries? If you wanted to stack them, wasn't it possible by just removing the sliding hold down at the front of the tray?
Sorry. What I meant, what C rating, maH and are they 2s, 3s etc. Nice work on the mod. Make sure those straps are tight!Specs not sure it was the Height but when stacked that sliding tray sits up 3/4 and now the body doesn’t have bubble no more so I modified it
