This 4S battery was charged to 4.2V per cells. Did some runs and then got this reading. How can I get 4.95V per cell?
I thought the battery checker could be an issue. I check several others and it was good. The external wiring on the battery looks fine, but I can't see inside. Maybe something is shorted inside?I think your battery checker or wiring somewhere is broken.
Have you plugged the battery into your charger to check the readings there?I thought the battery checker could be an issue. I check several others and it was good. The external wiring on the battery looks fine, but I can't see inside. Maybe something is shorted inside?
