th.son
- Senton 6s
- Thread starter
- #21
I personally don’t charge up to 4.2 as I read it shortens the battery life. I set my charger to charge up to 4.15.
Thank you. I updated the table to include this advice.
4.20v is the individual cell voltage that's correct.
Storage charge is 3.80v, you can charge at a lower current, if you're not in a hurry.
Updated the table above to put the storage profile to 3.8v
4.2V peak is where you want to go.
Storage for 3.8-3.83 is where you put them when your not going to use them. It's not good to store lipos for days at full charge and definitely not "empty".
Lipo's are very voltage sensitive. 3.2-4.2 is the working voltage. Although, 3.2 is pretty low, most set their LVC (low voltage cut off) to be at 3.4-3.5V.
If your charger has a cycling capability to discharge, running them down to 3.4V should be fine as it monitors each cell individually. It doesn't just drain from the main power tap like an ESC would.
I don't let mine ever sit at 4.2V or 3.5V. If I know I'm going to bash the next day, I get up early and charge. The first thing I do when I get home is put all my packs at storage voltage, even if I'm going to bash the next day. I get up early and charge them up again.
This sounds like a good habit to get into for when to charge/storage charge your LiPo's. I will try to follow this myself.
According to my chargers manual they do not recommend using the charger itself to do cycling. The manual says that most batteries will reach their maximum potential after around 10 charge cycles. They say though that you can achieve this just by general use of the device.
I am going to update my original post with a balance profile as well. Would I be using the same values to balance charge the cells?
One additional question, I am little confused about 1C vs 2C. How do I know I am charging at 1C vs 2C?
