Battery Charging
slfmde
Do you guys balance charge every time or maybe do it every other? I read balance charging is a little more stressful on the battery and can reduce its life span.
I balance charge every single time and I always put the batteries in storage mode after I am done using them for the day.
Balance every time. Doing so keeps the cells around the same voltage when driving so I don't have to stop prematurely if voltage of one cell is substantially lower than the others. Run 'em until they reach safe cut-off voltage.
Yes, best to always balance charge every time. I agree with crman1964 (good year by the way), and always put Lipos in storage mode when not using, for longer battery life. Your batteries will like you...
