It's OK, I have checked the dimensions. I was wondering for the energy. Thanks a lot for the information by the way.Do you have the length on your pack in question? That’s the one dimension that you should check. The Granite is a short wheelbase truck, but you can remove a battery block if needed.
What is the C discharge rating? If you have a link we can help more accurately.It's OK, I have checked the dimensions. I was wondering for the energy. Thanks a lot for the information by the way.
C ratings are not always accurate, but that said, that rating exceeds the minimum requirement and should be fine. ??It says 50-100 C
Hmm that seems extremely low, I get about 30-40 mins of bashing and 20-25 if I’m running it full throttle everywhere.What kind of battery life are you getting out of your packs? I'm using 3s 5000mah 50C packs and can only get around 5 minutes before LVC. Granted this is in a large backyard in cold temps, grass is probably 3-1/2 to 4" tall. I'm coming from RC crawlers and can run for an hour plus on one 2s pack. I'm guessing running the 3s Granite at top speed wheelying across the yard is what is causing the quick LVC but wanted a second opinion or more.
My batteries are: 5000mah 60c
That’s okay! ahh yeah that sport mini doesn’t look the best of things haha. It probably is that.Appreciate the response. I have a much better charger coming today. Had been using a Prophey Sport Mini so hopefully the Tenergy will do a little better job.
What times are you getting now ? I am experiencing low run times as well?I believe between the new charger and switching everything over to EC5 connectors performance was way better this evening.
Thanks again!
Where are you from? That has a lot to do with what you can choose from.Hey everyone. I'm the new guy. What battery is everyone running? A link would be great!
I’m from Columbus OhioWhere are you from? That has a lot to do with what you can choose from.
