You can get whatever you need via MyUS. They do handle lipos with some extra fees for dangerous goods handling. I received several packs via them. I am based in Saudi Arabia.
It's all personal preference, I run single 6s pack, find it easier to install in tray, charge, less wire, and probably saves weight. 5400 mah max.Do i get 6s battery or 2 3s
I bought 2 3S batteries since I have a few other rc cars that run on 3s only. I'll eventually buy a new 6S in the future though
Get a single 6s brick 5-6k mah. 50 C or higher. The only thing to consider in selection is the battery dimensions, listed in your 6s manual and its connector. Being able to Solder on the matching connector to whatever lipo you see/want opens up more selection.
Thanks all will use single 6s battery and will use MyUs?You can get whatever you need via MyUS. They do handle lipos with some extra fees for dangerous goods handling. I received several packs via them. I am based in Saudi Arabia.
By the way, Forward2me has the same service via uk. Hence, turnigy panther or CHLN (Europe warehous) are the best options! at least for speed runners.
