battery TRAYS
slick
just put theses in tonight not a big difference in power ,so it might be different in how long they lasT NOW
Did you set your charger to charge them to a higher voltage? If you just throw them on the charger it will charge the cells to 4.2v and you wont see a difference. Need to charge them to 4.3v I believe, then you would see a difference.
really 4.3 are you sure
yes i dd recharge them aT 4.3 .ill leT you know Tomorrow
If you have those exact batteries that are in the pic then yes. That is a High Voltage pack. If you have a regular 4s pack then it would be 4.2v per cell. Somebody correct me if I am wrong.
i have a smarT charger i let her do her thing.and yes next time i plug them in ill look at the charging rate .thanks for the heads up
Those are not the batteries that you posted? and it is not the charge rate but the final voltage per cell that needs to be 4.3.
