I own one, and the only thing I know how to use it for, is checking my regular alkaline batteries. I actually taped the instructions on the back, so I would never forget how. Pm me the instructions to check my lipos, and I'll make a new label to add to the back, then it will be able to do two things!I use a 90’s multimeter
what tester are you guys using to check up on your batteries? i have been looking at the Tenergy 5-in-1 Battery Meter.
Got a link? I looked at the 5-in-1 on amazon and it doesn't list that it does resistance.That Tenergy is the one I use what separates it from some of the cheaper ones is the internal resistance checker. Had a couple lipos that would charge fine but when used would die fairly quick then checked the internal resistance of some of the cells and some were really high. So I check the internal resistance of all my packs every now and then to give a little indication of the cells in the packs health. Plus it does give the percentage of each cells use but the cheaper ones do also. With the Tenergy it's just a quick way to check my packs.
Thanks. I must have clicked on one of the others then.Heres the link https://www.amazon.com/Tenergy-Batt...qid=1549943375&sr=8-1&keywords=tenergy+5+in+1 and it does say internal resistance tester in the listing it's a $1 cheaper on Ebay https://www.ebay.com/itm/Tenergy-5-...ash=item43e482cf40:g:GSIAAOSw5ShZxHLi:rk:1??0
I use the heck outta the Venom pro Lipo checker....gets'r dun
https://www.venompower.com/products...ulti-tool-with-balance-and-discharge-function
After googling them a bit... seems unless you spend a decent amount of money, the IR testers don't really work. This one comes up on quite a few forums, for $95 and you have to test each cell by hand:
https://hobbyking.com/en_us/wayne-g...esr-meter-for-100-10000mah-1-6-cell-lipo.html
