LTErene10$
- Outcast 8s
This may have been discussed before but some information for you gear heads.
Late night wrenchen on my outcast 8s I was getting tired of breaking beadlocks on the rovan 1/5 scale wheels. So there is an upgrade for this from primal rc. Get there aluminum beadlock rings and with some slight modification to your hpi/rovan 1/5 scale wheels and they will fit. Should be a major upgrade. Time will tell. Here is some pictures using a 9/64 drill bit to enlarge the oem holes. And use a 7/32 bit to counter sink the hole so screw will fit. Don’t go to far. Also cut half of inside screw hole with knife like this so inside ring will fit. And you end up with a finished product. Will be doing testing on this with more updates to come.
