Typhon BEARING AR610001 BLEW ON MY TYPHON 3S
  1. Typhon 3s
First thing that went wrong w this typhon 3s in the 4 months I've had it. Anyway, photo is attached. I found the bearings I need. Jw if anyone knows of an aluminum drive shaft model as well as a metal gear setup instead of whatever this one sis made out of. Cheers!
4 months on stock bearings, with no service? you did pretty damn good..?...that may be a record..?
For the spur gear check jennysrc.com. Look under the OutKast/kraton 4s. Pick up that spur gear the 4s is metal. You have to check daily. Best prices around.
Do they update there stock every so often? I've been eyeballing a few parts from them hoping the stock status will change. LOL!
I don't use this at the moment but one way to see if Jenny's updates their stock could be this service. When the webpage changes, you get an email. Checks 20 pages a day and one hourly check. I haven't tried it but it may help folks that are looking for certain parts at Jenny's
https://www.followthatpage.com/
Reading the FAQ could help get it setup.
https://www.followthatpage.com/faq
Yep that’s how I get my alerts. I use a page called visualping.com but it’s the same premise. ??
I imagine its the key to shopping at Jenny's and when I find that I need something I can't find, I'll try it out. First found it when I wanted some LP Backflips but they were in stock at HH by the time I got around to using it. I'm good for a set of those every couple months.
