Might work problem is the gear is plastic … :\ Anyone know any metal gears for this car?
I think Arrma has them in the works. Are you worried about breaking the teeth? The chances are slim to none on stock power.
It's a slide fit, and not a press fit. Therefore using two small flat screwdrivers, pry the inner race at 180 degrees apart. No need for fancy tooling.. just a little patience
this bearing puller is made just for this purpose RC Bearing Puller/Install ToolView attachment 28880
thats what I thought I was going to end up doing a couple of nights ago.Real men use their teeth... just sayin’
