This is the one I haven't changed bearings in slipper clutch. Thank you for answer ?I think I remember seeing that bearing on the exploded view. https://www.arrma-rc.com/part/ARA620003
Page 3 here. https://www.arrma-rc.com/pdf/exploded-views/ARA102692.pdf It goes on the slipper clutch pad/spur gear.
Usually Jims bearing will send the additional motor bearings if you select to include them at time of purchase. Depends on the Rig in question I imagine. Maybe that's why you have them? I did not know that the drive shaft stabilizer bearing was optional?I got the Jims kit for Outcast 4s, I have 3 left over, one very large, which I think may be for the optional stabilizer on the center shaft. The other 2 are tiny, and someone mentioned he includes motor shaft bearings, not sure if those are the ones.
Where you been? We needed you here.The large one is for the center shaft that would be needed for the center shaft support in the LWB chassis. The two smalls one go inside the diff in between the two diff outputs. IMHO you don't really need to change those (not right away anyway).
Did you end up changing the motor bearings? I just replaced all of mine as well but didn't mess with the motor ones, I opened it up and it looked really clean, didn't wanna pull it apart if I didn't have to.Changed all the bearings in my 4s outcast but there was one bearing in the kit marked 10x15F. Where this bearing fit? Location is bellow.
You were 90% there, should have changed out the motor's bearings. The stocks may look clean but they aren't all that. Imo. ?Did you end up changing the motor bearings? I just replaced all of mine as well but didn't mess with the motor ones, I opened it up and it looked really clean, didn't wanna pull it apart if I didn't have to.
Yeah, my kid really wanted to take it out, Ill be switching to the LWB here soon so I will do it then, how difficult was it to remove?You were 90% there, should have changed out the motor's bearings. The stocks may look clean but they aren't all that. Imo. ?
That bearing goes inside the sliper clutchChanged all the bearings in my 4s outcast but there was one bearing in the kit marked 10x15F. Where this bearing fit? Location is bellow.
