Outcast Bearings for the Outcast
dwblue00
Michigan
I'm going to order bearings for my outcast from Avid racing. Are the bearings the same for the Kraton, talion, and typhon? Reason I'm asking is because they don't specificly list the Outcast. Thanks!
chevys10zr2003
Minnesota, USA
Kraton 6s, Senton, Typhon 6s
Yes, the bearings are the same. The Outcast is basically a short wheelbase Kraton.
Mr.Duke
~ Gray Matter Minimalist ~
Staff member
NC
Kraton 6s, Notorious, Outcast 6s, Talion, Typhon 6s
They're all the same quantity and size between those models
10) 8mm x 16mm x 5mm
4) 15mm x 21mm x 4mm
2) 8mm x 19mm x 6mm
2) 5mm x 11mm x 4mm
* if you want to upgrade the brass bushings in the steering posts to bearings you'll need
4) 6mm x 10mm x 3mm
chevys10zr2003
Minnesota, USA
FastEddy's kit includes ones for the steering posts. I prefer his bearings over avid's. I ran avid's a long time ago, but they don't seem to hold up as long.
I have always thought this too. To me, it seems like the Avid's are freer spinning but don't last as long as Fast Eddy's, without cleaning/relubing of the bearings. I have always thought/guessed that they use lighter oil to make them have less resistance but a little more maintance. I can't really say for sure but that has been my experience with them as well but I do like the revolution bearing concept with one rubber seal and one metal shield.
dwblue00
Michigan
Ok great! Thanks!
2) 8mm x 19mm x 6mm
2) 5mm x 11mm x 4mm
4) 6mm x 10mm x 3mm
Thanks for the info. It's greatly appreciated. I already did the steering posts.
dwblue00
Michigan
Ive used Avid bearings for a long time.....kinda like force of habit.....I need bearings ok.....place a order to Avid. I have not tried fast eddies bearings.
olds97_lss
Bash Break Repeat!
Dekalb, IL
Yeah, over the past 20 years of RC, I've tried many. Acer, Boca, Avid, Duratrax (what the LHS had), vxb and fasteddy. Pound for pound, fasteddy seems to hold up for me.
dwblue00
Michigan
Well I did end up ordering Avid bearings. Kinda went with who I know and bearings I've used. If the Avids don't hold up, I'll try the fast Eddie bearings. At a $1.00 per bearing its not a huge cost to replace if necessary.
Crash
Saturn
I used Fast Eddie when I built my 5t and they were great. But not so much in my Kraton. Going across a field in my Kraton it seems to role for ever after letting off the trigger now that I replaced them with Avids. I replaced them 2 months ago and they're still like butter. But as with every product people will have their own unique experience with their rc. Fast eddies are still great bearings though and you wouldnt be making a mistake if you used em.
Create account
Log in
Outcaster Outcast Replacement bearings for Outcast? Arrma 6s BLX 4
LMC Fast eddy bearings Chassis & Drivetrain 15
ArrmAh Outcast Jim's bearings seals Arrma 4x4 9
P Senton Bearings Rant Arrma 4x4 34
Similar threads
