ptsWolfman
- Granite
- Senton 6s
I have to really say that the stock bearings in these Arrma vehicles are just really, really bad. I love these trucks to bits but it has become obvious that almost as something you need to do before running even for the first time is swap out to sealed bearings.
I ran my Senton BLX on 2S for a day out in a dirt area and everything was fine. I got in some 3S packs and went for a run and the two bearings inside the transmission (so the 2 on the spur/slipper shaft) EXPLODED.
I don't mean they just fell apart... I mean I had bits of bearings here and there and (worse) tiny little ball bearings everywhere.... Including (and this was bad) wedged into the metal teeth of the spur gear.
This caused extreme wobble and rough spinning. I couldn't believe it.
Thankfully I had some bearings left over from a different project and I was able to swap them out. Between that and having to use an awl to pick out the ball bearings from the teeth, the truck is running fine again but I honestly don't think that is something that should have happened in the first place.
For the few cents it would cost Arrma, I really wish they'd give proper bearings to begin with.
/end rant
/end rant
