BEC for HV steering servo
Drtybird
I am purchasing a jx cls hv7346mg for my arrma kraton. I am running 2x3s and will be finally running it on 4s till motor upgrade. I will be letting my GF daughter be running on just 3s. I want to go ahead and put this in while I'm putting the servo in any recommendations on amp rating , volt setting and brands that will be a good investment
Jerry-rigged
Have you seen my LVC?
Texas, Baby!
4x4-Mega, Kraton 6s, Outcast 6s, Typhon 6s
That servo is plenty strong on 6.0v. If you are going to upgrade the motor, will you also upgrade the ESC? Most of the popular big power ESC's have adjustable BEC's.
Personally, I'd wait on the new ESC, if you are planning that route.
Drtybird
Yes I am looking at a tp 4070 and hobbywing ESC 6-8s. I am going to be running 4s till I get motor and esc with new 6s lipo. I know the blx 185 should power the servo but I feel it would be a good investment to help from surging esc
Nitr0EngiEx
I used to think the same thing but I actually have issues with small wires on bec breaking
joostin420
MA/NH
Fazon, Kraton 6s, Outcast 6s, Senton, Typhon 6s
The Servo is definitely powerful enough on 6v. In my x-bug I left the max 5 esc at default bec setting of 6v and it is powerful enough to turn the madmax giant grip wheels/tires with ease. I just purchased another of these servos for my senton.
Drtybird
I was looking at the cost of $20-30 and save ESC as to have the servo load esc and do damage
Drtybird
How to set ESC for 6v for savox 1230 sg
joostin420
MA/NH
The hw max 5 esc factory default is 6.0v bec I believe.
JvG
Everything is relative
The Netherlands
BigRock 4x4, Kraton 6s, Typhon 6s
What the blx 185 ? Is it set at 6v
Yes it's 6v. I think it's a good idea to install a BEC with heavy powered servo's, also on 6v. I installed a Savox 1283sg without a BEC and it killed my esc (which probably was at its end anyway). So it's a small 20 bucks insurance which relieves the esc.
Drtybird
I just installed the 1230sg and want to be sure everything is right, I have the V3 running 2x3s. Installed bearings in bellcrank it's still under 2.5 yr warranty but want it right to bash with
