chrisexv6
Looking to improve cooling on our Kraton....I picked up some 12V Delta fans. They run OK at 6V, but much better at 12V. They seem very similar to the NTF stuff.
I know the NTFs are preferred to run on a separate lipo, but would there be any harm in using a separate BEC instead? I figured I would solder up a pass-through from the battery to ESC (XT90 male/female), then tap off that as input to the BEC. Output from the BEC would be 12V and feed a splitter for the fans.
The only question is how to switch them on and off. I know I could wire in a manual switch, but wheres the fun in that? Are there BECs that have some sort of trigger input (like a relay)? So you could wire it to the receiver (or existing BEC) so when it gets power it triggers the external BEC to come on.
Maybe completely overkill, or unreliable, or both....but just a brainstorm I had.
-Chris
-Chris
