Been wanting a crawler any suggestions...
Currently reading:
SrC
RC is a lifestyle choice
Hospitality Award
Solutions
1
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
Quick question... Adding weights to the inner side of wheel or weights to the axle ??
Which is best, I know that both of them are are going to help lower the center of gravity but are the ones that bolt to the wheels any good as I've seen quite a few recently that look like disc rotors which I think are pretty cool 😎
Weight on the axel is better IMO. Why create stress at the wheels. Tried both. I prefer most any ballast weight at the front up forward most of the time. My rigs at least.
Edough13
Bashing, Speed running and family!!
ArrmaForum Fan
Hospitality Award
Solutions
1
Northern California, USA
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
Was messing around and decided to try and fit an old beat to $hit Granite body on the crawler. Well not too bad what do you guys think? 20210905_192707.jpg 20210905_192735.jpg 20210905_193840.jpg Little bit short but not terrible. Now my Bigrock body would fit perfect but wouldn't have a body for it unless I swapped it for the crawler body and extended the posts🤔 I mean it looks pretty sweet but don't think it would hold up to my bashing very long... 20210905_193207.jpg
KvConivore
AKA Tunedpipe
Military Veteran
Looks like a good thread to post my Bomber. The electronics were already installed when I purchase it but I added a few cosmetics stuff.
She screams..
Axial RR10 Bomber.
Metal frame
Tekin Pro4 HD brushless, sensored motor
Tekin RS esc
Tekin T440 servo
External bec
Vanquish Method wheels
Proline Hyrax 2.2 tires
KYX Aluminum body panels
Vanquish knuckles and lockouts
Diff covers
Roof protector
Window nets
Motor fan
Decals
Edough13
ArrmaForum Fan
Hospitality Award
Solutions
1
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
KvConivore
AKA Tunedpipe
Military Veteran
Aluminum wheels is always a good upgrade as far as I'm concerned. The tires on the other hand, it's hard to say. I have cheap sets of tires and they work for me.
Edough13
ArrmaForum Fan
Hospitality Award
Solutions
1
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
Aluminum wheels is always a good upgrade as far as I'm concerned. The tires on the other, it's hard to say. I have cheap sets of tires and they work for me.
I figured for not even $20 it's worth a shot and if they aren't softer than the stock set I'll just pull those off the stock rims and put them on the bead lock rims as they are not bad at all just need a little more beefy tread IMO for better grip but with a heavier rim they may work better🤷🏻
Edough13
ArrmaForum Fan
Hospitality Award
Solutions
1
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
So went with a different set as they were comparable in price and are 120mm over the first set I was looking at being 110mm. Also full set with bead locks and tires/foams so have to see how tires and foams feel when I get them but for the price can't complain. Screenshot_20210906-114322_eBay.jpg
1.21 Gigawatts
Got a lot of work done on my TRX4 kit this weekend. I painted and assembled the body which took the most time. I also spent a bunch of time rearranging the electronics trying to figure out the best layout. I am still waiting for the motor to be delivered, which I need to try to get the balance right. I'm leaning towards mounting the esc in the stock location, the receiver in the front of the battery tray, and the battery on the right floor board (in place of the stock receiver box). I don't treat my rc trucks as submarines, so I don't need the huge waterproof box for a tiny receiver. I figure mounting it in the battery tray is high enough to not get wet. My battery is small and light (3s, 1500mah soft pack), so I'm hoping that it will balance with the motor being offset to the left. I was thinking about removing the battery tray, but it seems to provide a lot of structure.
SrC
Hospitality Award
Solutions
1
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
The super swampers in the first one are fine. But if you look at the super swampers mounted to the wheels (Red) they are called super swampers also, but a differnt tread. And I have those. But they don't have The real "Rocks Tyre Super Swamper" tread like in the first tire. The real super swampers have a unique cross rib in the center for self cleaning of mud and snow. Many tires out there called super swamper. A Name copy because originals known to one of the best. But only one original tread design. I also have the RCAWD Super Swampers. The original licensee of this Swamper. Both are good tires. But the real Super swamper tread works well in everything. RCAWD uses a better rubber.
Hope you understood what I said.
The wheels are nice. I like the Yellow or Silver myself.
Edough13
ArrmaForum Fan
Hospitality Award
Solutions
1
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
Not too worried about the tires as the stock set on it now are actually really decent tires so if the tires mounted with the red beadlocks aren't great I'll just swap them out. Ya I did like the first tread pattern better as you mentioned but also they were a smaller tire at 110mm which stock now are 120mm so another reason I went with the red set above being 120mm also. Another question if you can help is am I able to go to the 2.2 size rims and tires without issue as I noticed a lot more I liked and better quality in that size. I'd figure would be fine just a larger rim and tire is all but again completely new to crawling so just want to make sure.
SrC
Hospitality Award
Solutions
1
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
The OE TRX tires are very good. Many even tune them better with Crawler innovations firm front foams and mediums in the rear wheels. What I did. But changed over to Pit Bull Rock Beast XL's on my Trx4. Incredible tire. Very expensive. Hands down the best Crawler tires out there. But I paid hard for them.
Sticky as all heck. Excellent tread grip in most anything, Snow also.
Sometimes I trim some lugs off the tread and experiment with better traction. Like with the Axial Falken Wild Peaks. The OE tire. Cutting a center set of lugs off made them better for climbing. Used side cutters.
Pat_ranch
ArrmaForum Fan
Bozeangeles
  1. BigRock 4x4
  2. Kraton EXB
  3. Kraton 4s
  4. Notorious
  5. Senton 3s
  6. Typhon 6s
  7. Typhon 3s
I have tried either one the linked tires or wheels. The wheels in the later post look like injoras, which are decent. And they have knockoff hyraxs on them. It's totally worth it to drop some $$ on hyrax, or the new trencher crawler tires. I actually got to test out my trenchers today against some hyraxs, and they're pretty even. But you're looking at around $100 for either one of those.
With the chitanium knockoffs, it's a gamble. Sometimes they work
SrC
Hospitality Award
Solutions
1
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
Yes they are Hyrax knock offs ( treads) exactly. Yet they say Super swampers. Have them. The rubber is harder than a PL Hyrax.
Anyone know of the Pitbull Rock beast XL's?
Great tires.
Premium price though. Wish they were cheaper. my other 2 Axial Crawlers would have them too. :cool:
https://pitbullrc.com/products/pb9011nk
Mounted to a set of VP wheels too. $ouch$. Crawling can get crazy $$.
Dendawg13
Da Beach
  1. BigRock 4x4
  2. Kraton 4s
Been really thinking about getting a crawler lately and was wanting some input for what's worth a sh!t and doesn't need tons of upgrades out of the box. Also don't want to spend an arm and half my left leg for one either so looking at a decent budget friendly rig. Have looked at the scx24 but not sure I want something that tiny more so would like closer to a 1/12 or 1/10 size. @Pat_ranch I know your a crawler guy what's your input Sir? Ideally would like to stay in the $200-$300 max range. Appreciate any and all input and suggestions!!
Absolutely love my Danchee Ridgerock from Redcat Racing. Budget friendly around $115 and crawls over everything with the right tires. Stock tires are a little toy grade, but ok. Only thing I've done is moved the ESC to the battery compartment,removed ESC compartment, and went with cantilever suspension. Impressed with.its performance. PXL_20210830_225848332.jpg PXL_20210830_225810488.jpg
BashingBrian
Get Schwifty #ArrmaAddict
UK..
  1. Infraction
  2. Kraton EXB
  3. Mojave EXB
  4. Outcast 8s
  5. Outcast 6s
  6. Talion
  7. Typhon 6s
Where I'm located there aren't so many rocks 😉, it's more forest woods, mud and wet/dry..
What tyres would be a good choice ??
The cheapo ones above that I bought were chosen more on size and looks to be honest...!!
I don't know if it's just me, but the stock SCX10lll tyres are too tall in my opinion 🤔 so I went just slightly less tall with my chinesium ones...
KvConivore
AKA Tunedpipe
Military Veteran
One of the very reasons my crawlers are my favorite rigs. There is a thousands of different direction you can go with them. No pun. :p
SrC
Hospitality Award
Solutions
1
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
What I learned with crawlers is that Creativity can go a long way. So can the money in your wallet. Once you figure out Crawlers, you will find that $$$ is not always the answer. There are DIY tricks that accomplish the same. But tires will make you or break you. IMO. If you get set of shoes that don't work like, you expected better traction etc., try trimming the treads with side cutters after finding where/why the tires don't work just right. Before buying another set.
Bead locks makes tire changes easier and to fine tune them with different closed cell foams. No reason to have glue-on tires and wheels with Crawlers.
Edough13
ArrmaForum Fan
Hospitality Award
Solutions
1
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
Yes I'm finding that out but my wallets not prepared or willing😂 I am very happy though that even stock with me adding some weight to the front and changing shock positioning I've already seen improvement. I think with more weight down low adding the metal rims will help even more and man this thing will be solid! I tested out my course yesterday and rig did great. Had some issues with traction as I layed sand down over the rocks and wood to help keep it in place from moving so sand on the rocks made it a bit slippery and challenging. But still made it through forwards and backwards with very little hangups so absolutely stoked this rig is performing so well for being a "cheap" crawler at $250 reatail😍
