Is there a belted tire option that fits the Mojave?
Watching this with interestIs there a belted tire option that fits the Mojave?
You could always wrap them in fishing line. What's your front diff fluid weight?It’s definitely bashing and with the power of my Castle system the tires are ballooning big time and getting cut down by rocks.
I put a least 1 mill in all my diffs.ill never race my mojave on a track..I like ridiculous power an holeshots,aggressive ripping...I've used belted 2.8 duratrax lockups5.4 inch.mx28 belted...5.05in.an belted badlands 5.85 on mojave..your best bet is the mx28s...expensive 50$par raid wheels has different backspacing insurts.inserts. Down FAST ON STREET THOU
send ya some pics when I get home
Awwww you got more than that....u da MOJAVE KING..SWEET PICS BROTHERMx28 belted-too small... View attachment 151972
belted proline street fighter-too big...View attachment 151973
Belted duratex 2.8-wrong offset,too small..
sweeps terrain crusher belted 3.8- very nice...
grp 1/5 belted - requires square adapterView attachment 151978View attachment 151979
Hope this helps
Those were just the belted ones;-)So my mojave isnt all together at moment has kraton suspension and is alot taller an bigger than stock mojave..so fitment will be different for you..
1st mx28s belted
Duratrax belted
Are your 2 best options i can think. Of
I did blow out sidewall on belted duratrax here
1st mx28s belted
Duratrax belted
Hope this helps
Hope this helps
Or proline badlands or trencher LP 3.8. They’re not belted but strictly for off-road. Any on road use they’ll balloon too much.Thank you for the pics!
This is solid thank you. Sounds like when it boils down to it the Sweeps Terrain Crushers are your recommendation for Bashing?
the sweeps tend to be a lil on the heavy side so anything higher than a 18t pinion may cause some heat issues.
when she was 1650kv she seemed to handle them just fine. But the stock blx 2050kv was a struggle unless geared accordingly. View attachment 152002View attachment 152003View attachment 152005View attachment 152006
Just about anything over stock or talión Katar will require raising the body posts and or trimming.
No. Just raise the post
